Results 1 to 15 of 15
Thread: Flex plate shimmed
04-13-2009 #1
Flex plate shimmed
I took off my flexplate to give it a good look to ensure it ws in good condition before the new tranny install. I found that there were washers between the flexplate and crank. I put it back on without the washers and found that the mini starter ring gear made contact with the flexplate when not engaged. The starter was also shimmed down from pan rail with 5 shims.
I put the washers back on behnd the flex plate torqued the bolts down and the starter worked fine again.
Will the flex plate be ok with these washers as shims?
70 Nova - 406 sb -488 HP/504 TQ-3:73's
http://s66.photobucket.com/albums/h266/steelratnova/
