      Mar 2003
      Fallston, MD
      stock ecu controlling ac
      I have been working on my 00 camaro harness for my conversion I have it pretty much done but I want to run the ac through the pcm so the fans work right and the idle kicks up. Their are two ac wires that I havent removed ac request and ac clutch relay control. I beilve I should hook up the request to my Vintage air control. What is the clutch relay control hook up to. I reaserch on ls1 tech couldnt realy find an answer. I did find some info on people using the stock presure switch do you need this for the computer to turn on the compresior?
      Brian Schein
      Oct 2008
      texas
      Here is one link I found with a quick search hope it helps. Good luck with your build
      http://www.ls1tech.com/forums/conver...-computer.html
      This is Larry Callahan adding to Rocky's profile.
      I'm sorry to say that we have lost Rocky.
      RIP....
