    Results 1 to 10 of 10
      Snohomish, Washington
      Question about deep scratches.
      Hey guys, After painting the tempest today there are alot of deep scratches on the trunk lid, What would be the best way to go about "getting rid" of them. I have some evercoat glazing putty that ive never used. Should I use that? Or should I just use my filler?
      Matt
      Canada
      scratches
      Did you put a clearcoat over it already or did you use single stage
      Jeremy
      79 Trans Am " In Progress"
      good ol rattle can paint nothing special but the scratches bug me.
      Matt
      Canada
      what did you sand the primer with before you painted it?
      Jeremy
      used 120 grit but these things are deep. didnt notice them at all. Looks like a razor blade was dug into it
      Matt
      Canada
      ya 120 scratches are too big for paint to fill in on primer, sand it down with a block with 180 grit dry then go back over it all with 400 wet and if you can see them still then use 600 wet. this will knock the primer down to a near flat surface. that should get rid of your scratches, what colour did you paint it?
      Jeremy
      its black.
      Matt
      Canada
      if you take a rattle can of white paint and put a quick mist coat on it as you sand it the white paint will stay in the scratches and disappear as you sand the scratches out
      Jeremy
      I will give that a try
      Matt
      Canada
      k let me know and that is going to be a sick gto when ur done, keep adding pix of it
      Jeremy
