Results 41 to 60 of 78
Thread: Rick's tanks at the track
It's been a long time waiting...I talk to Hector the other day and it sounds promising that I will get my creation soon. He said it was all tacked up and he was able to stay about 80% to my drawing. Once I get it, I will post pictures of what I can. Looks like the pump is going to be mounted offset in the tank instead of the middle(passenger side). They also made there own version of stainless check balls. Can't wait!
Ron DeRaad
68 Camaro RSx
Darton Sleeved LS9 - 434ci (4.155x4.00)
AFR LSX245 Heads (12:1cr)
660hp/588tq
11-18-2009 #2It's arrived!!!!
My Rick's Tank is finely here. Here's some pics....
I think it turned out nice. There are a couple areas I shook my head at, but I think overall I think it will work.
I put some captions verbiage over the issue pictures that I will inform Hector about.
Not sure about the vents at the top corners? They go to the back of the tank up higher then the threaded bungs in front of the tank. I see fuel coming out every time I land on the power or fill to the top. I will try, but I think they will be plugged and a vented from the fuel neck as Mark said.
Problem Photo: Fuel will go right around the sump to the other side of the tank. Should of had a baffle tack welded on each side.
Solution: Stuffed 4" fuel cell foam in 1.5" gap to stop or dramatically slow fuel from going around. Very tight fit..my fingers and arm were sore..shouldn't move.
Unfortunately with the A1000 pump, it wouldn't allow for a second baffle.
More Fuel Cell Foam to help.
Ron DeRaad
68 Camaro RSx
660hp/588tq
10-23-2009 #3
