      Holmes Hollow, Ontario Canada
      69 camaro master
      Is a disc/disc master from a 69 camaro a 1" bore?
      ____________________________________________
      Scott
      Loganville, GA
      I believe the master cylinder used on the JL8 system is a Corvette Master and they are 1" for manual brakes and 1-1/8" for power brakes. I am using the manual one on my El Camino. It was a direct bolt up, including the lines.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Does anyone know of a master that has a 15/16ths bore? I did a c5/lt1 swap on my firebird, I know the early 70's master and booster will do the trick but its kind of ugly and I'm looking for something with a flatter booster that would look more stock.
      Scott
      Quote Originally Posted by Randy67 View Post
      Thanks Randy
      Scott
      Pittsboro, NC
      The master cylinder that comes with Baer's track/track plus front system has 15/16" cylinders.
