    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    1. #21
      Henderson,NV
      Add it to my list. LOL Mine got a little noisy after 6-7 autocross runs with about 3-5 minutes rest between.
      Todd
    2. #22
      Rockford Illinois
      Jim,
      PS heat is a real problem, and having a gauge on it can give you a warning before it fails.
      The same is true in the rear, but I haven't heard as much about possible problems there.
      If it were me, I'd do the ps pump first. Maybe put sensors in both, and switch the gauge back and forth?
      jp
      I am going to put it on the PS and check with Racepak to see if I can put a switch in.
      With the way it is programmed it might work as long as the sensors are identical and the signal doesn't get distorted by the different length of cable ? Good question to ask.
    3. #23
      Central CA USA
      I have read posts on the net forums from Camaro SS owners that reported PS overheating at autocrosses even with the SS cooler installed.
      David
    4. #24
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by WS6 View Post
      You can get one off an LS1 Fbody. It's the aluminum thing that was in the upper radiator hose on many of those cars. I believe they had to be SS or WS6 cars. Those work well for what they do. Matt is right though, a good PS pump won't need a cooler. If your pump is stock, it's not a good pump. It spins too fast is what ti comes down to. So doing auto cross duty will kill it and or over heat the fluid. Turn One has finally made an LT1 pump and it's a great piece. http://www.turnone-steering.com/lt1.html These guys know their stuff
      I have a Turn One pump.. I don't need a PS cooler. They know thier stuff.
      If your pump is stock then you most definetly need a cooler. Use to boil the one in my 2000 SS all the time.
      1968 Track Rat Camaro:
    5. #25
      Feb 2009
      So-Cal
      Based on what I have read and what I experienced I just bought/received my Turn one pump. I will post a few pics when I get the DSE pump off.
      What Turn one said is that they do not want temp to be above 275. So like Steve said in most cases you don't have to run an external resovoir or cooler.
      I have a DSE pump currently, no cooler. I was going to go the cooler route, but it seemed like a crutch more than an actual fix. Plus with space being a limited commodity, I would rather not have to run a cooler than have too.
      James Faria
      07 GT500 740rwhp
    6. #26
      Henderson,NV
      Last autocross I had no noise at all with new r888's and a tight course. Go figure...I do have a rack and remote resoirvoir which I think helps cool. I'll probably chance it on the road course.
      Todd
    7. #27
      Feb 2009
      Laramie, WY
      Anyone know if KRC or Turn one make a pump that will work on a small block Buick, I would like one for my wagon
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
    8. #28
      Auburn, WA
      Quote Originally Posted by PT Sportwagon View Post
      Tim
      I'd imagine you'd need some custom brackets. If you can find a bracket set to fit a Type II GM pump to your motor, the KRC or Turn One will bolt right in.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
