    Results 1 to 9 of 9
      Apr 2007
      Huntsville, Tx
      LS1 Rear Rotors bolt pattern-problem?
      Working on final assembly on my 69 firebird and I have installed the LS1 rear brakes on my 10 bolt rear. While I didn't notice this before looking at the rotors I puchased, there is a noticable space difference on the bolt partern of the 69 5 3/4 bolts and the LS1 rotor holes. Should I be concerned with this? Do I need to add bushing to make up the difference? Or is this not an issue I should be worrying about. You thoughts/comments are greatly appreciated. Here are some pictures.
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      Aug 2005
      Patterson, NY
      You'll be fine.
      Jason Scheer
      boerne texas
      your studs are 1/2 .your rotor has 14mm holes.
      rick k
      i think the newer Impalas use the same rotor but with a slightly smaller bolt pattern, so the aftermarket parts are just drilled with slightly oversize holes to fit both applications.
      Oregon
      Quote Originally Posted by novaderrik View Post
      X2...it's a 5x118mm pattern with oversized holes to accommodate multiple applications. I believe the OE parts were the same as the aftermarket replacements if I'm not mistaken. Since the rotor should be hubcentric, the wheel stud hole size and/or location isn't critical.
      Tobin
      KORE3
      It's what I does.
      Apr 2004
      OKC, OK
      Rotors are hub centric, so the oversize holes are not a problem.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Apr 2007
      Huntsville, Tx
      Thanks, guys. This is why this site is so great!
      Sam
      Nov 2004
      Dallas Texas
      rotors
      So Sam, how long till yours is driving?
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Apr 2007
      Huntsville, Tx
      Quote Originally Posted by zman1969 View Post
      Oh, I don't know. I was hoping for May, when the shop said they would have the car painted by X-Mas, but I didn't get the car untill the end of March. So hopefully by the end of summer.
      Sam
