      Dec 2008
      Dynacorn Convertible Issues
      So here's the deal. Bought this car and now am discovering a few problems with fitment.
      This issue is with proper fitment of the Convertible Top Frame just where it mounts onto the Right and Left rear sides. I've included 2 photos but it's gonna be difficult to describe, bare with me here.
      The Welded mounting points on each side of the car, are not the same distance apart from the outside of the car. One is Welded in too close to the outside of the car. If you will look at the TOP of each mount. Notice the V spacing at the top of each. One has more spacing for the Convertible Frame than the other. Only 1/2 inch more but what a difference it makes. The factory used the alignment holes as a guide and tacked them in place. The holes are lined up but where they were drilled in the mounts were off, so the mount on the Drivers side is off. Result, Convertible Frame rubs as it moves up and down and it sits on the side panel.
      Question: Best way to correct this WITHOUT welding. I can't move the car and don't own any welding equipment.
      NY
      Spacers or shims, if you have the room.
      The needs of the many outweigh the needs of the few.
      Feb 2008
      No way to fix it right with out drilling out the welds , moving it over , and weld it back in the right place !!!
      You just need to run down to a Northern Tools or a Welding supply shop. Pick you up a small Mig welder with gas (Hobart, Lincoln, or Miller) ** for $ 300 to $ 600 ** Just fix it right !!! You will need a welder to fix other parts on this body too.
      Mike's Custom Car
      1-803-329-2835
      www.mikescustomcars.com
