    Thread: 3.73 or 3.90?
      Georgia
      3.73 or 3.90?
      My Camaro needs a new ring and pinion. It has an 8.5" 10 bolt with a 3.73 (which came in the car). During my build I added an Auburn posi but just swapped over the ring without removing the pinion.
      The thing roared before and after the change and I believe a new set, properly installed, should provide an improvement.
      The car has a World Products 427 crate motor, a TKO 600 and 275/40-17 rear tires (25.66"). I don't mind first gear being a bit shorter and I'm leaning more towards the 3.90 just because I'd like to see the change (from the 3.73), but I'm not wanting to go as short as a 4.11.
      My question is 3.73 or 3.90? I basically use my car for street use with some spirited weekend runs but no track events.
      3.73
      (1st) 2.87 x 3.73 = 10.71
      (2nd) 1.89 x 3.73 = 7.05
      (3rd) 1.28 x 3.73 = 4.77
      (4th) 1.00 x 3.73 = 3.73
      (5th) 0.64 x 3.73 = 2.39
      3.90
      (1st) 2.87 x 3.90 = 11.19
      (2nd) 1.89 x 3.90 = 7.37
      (3rd) 1.28 x 3.90 = 4.99
      (4th) 1.00 x 3.90 = 3.90
      (5th) 0.64 x 3.90 = 2.50
      I'm going to Summit in the morning to pick up everything along with a new Moser cover.
      1968 Camaro - World Products 427 SBC, TKO600, 8.5" 10 bolt, Touring Classics brake kit, DSE springs, Gulstrand mod, Koni shocks, AAW classic update harness, Vintage Air
      So Cal
      The 427 doesn't need any more gear than the 3.73.
      The final drive ratio in 1st gear is plenty low for a nice launch, but not so low that wheelspin will be a big problem (yet it will ).
      The 2.39:1 final on the highway will make a nice cruising gear, your rear tires are fairly short so I really can't see any point in gearing your car any lower than the 3.73s.
      But it's your car, if you really think gearing it a tad lower will satisfy you, then go 3.90. If the engine has a big enough cam it might just like the 3.90s better.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Georgia
      Funny you mentioned the cam. In 5th at about 55 mph the car stumbles and bucks a bit and I've been told that's because it's "on top of the cam", whatever that means. This is part of the reason I'm leaning more towards the 3.90
      Nov 2004
      Dallas Texas
      imo I would find a good used set of 3.73 GM gears they usually run quieter than aftermarket gears - I AVOID using a/m gears for this reason
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      So Cal
      Quote Originally Posted by Marty G Cars View Post
      Too much cam and not enough gear always makes the engine buck and kick with a manual trans.
      If you want to be able to keep it in 5th at 55 then you'll definitely want to go for the 3.90s or even 4.10s. If it's right on the edge, 3.90s will do the job.
      Nov 2004
      Dallas Texas
      gears
      I have a couple of sets of 8.5 fact GM 4.10 gears in great cond - both sets came out of front axle 4wd so 99% the were just coasting - if you want to go that low
      Rich
      69 R/S Z28 302
      15 Camaro ZL1
      Georgia
      I picked up a Richmond 3.90 set at Summit yesterday, but thanks for the offer.
      Nor Cal
      I would go with 3.73. I had this same dilemma with my setup and due to the TKO tall first gear it is almost worthless with any decent amount of power and a taller rear gear. Everyone told me to go with a 3.50 or 3.70 in my 9" (had 3.89s in it) and I went with 3.70. Should be on the road soon to see if I made a good choice!
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
