      Dec 2008
      Missouri
      2ND Generation camaro steering
      I need help please, I was close to getting my 79 camaro going until I began to put my steering components back on and relized my stock pitman arm hits my altenator. I put a steering gearbox off a late 80's iroc in my car. When I bought it it came with a pitman arm that has a drop on it, that might work if I remachine the taper the other direction on it. The rest of the steering would also have to drop, I guess the idler arm also ? I don't know if others on here have run into this. I don't know alot about steering geometry or everything else on these forums for that matter,most of the cars on here are so awesome and people are so knowledgable. I am a rookie trying to learn,so I am looking for some guidence. Thank you for any help.Dan
      I'm no expert on steering geometry either...might it be easier to relocate your alternator than to re-engineer or modify your steering?
      Good luck,
      Paul
      Feb 2007
      I had the same issue, it looks like you have a LS-engine? I have a
      LS1 with the brp mount kit. Is what i did wad cut a slot in the case of the alternator for the pitman stud to pass threw.. it does look like your is closer than mine is? what mounts did you use?
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Dec 2008
      Missouri
      Yes, I probably should try to relocate my altenator. I was hoping there was some way I could fabricate components to lower the steering down a little. I made my own motor mounts over winter holidays and had the motor in and out several times but did not have the altenator on or the steering box . I should have I might have forseen this problem. Thanks for writing.Dan
