    Results 1 to 19 of 19
      Jul 2007
      Los Angeles, CA
      Line Lock kit recommendations?
      Who makes a good line lock kit? Hurst? Moroso? Any suggestions or experiences with different kits would be welcome. Would be going into a 69 Camaro.
      Thanks in advance!
      Florida
      I've had Hurst kits with no problems.
      I have run most of the common brands at one time or another....no real difference. but you might want to invest in a brake pressure gage to go with it.
      Jonesboro, Arkansas
      I have the Hurst version, no problems..
      Carl Wilson
      Southern Indiana
      Hurst and rebuildable too, I still have my old one!
      Jul 2007
      Los Angeles, CA
      Hurst seems the clear favorite.
      I've had great luck with these solinoids:
      http://store.summitracing.com/partde...5&autoview=sku
      It comes bare, which is just fine, because I always end up using my own wiring, switch, and indicator lamp.
      Jun 2006
      Katy,TX
      The Summit brand side by side looks identical to the Hurst.
      MD
      Never had a problem with the Hurst.
      san diego
      i have a summit one, it works good and good price.
      Jan 2009
      Hurst... all the way, i knew someone who had a solinoid fail a mile or so from his house, lets just say that the flat spots on his front tire from the ride home made for a bumpy ride...
      May 2000
      Quote Originally Posted by buds87gn View Post
      So when they fail then lock the brakes up?
      Huntsville, AL
      I have used both the Hurst and the Jegs brand, no problems with either one.
      Jul 2007
      Los Angeles, CA
      Thanks for all the suggestions, ended up ordering a Hurst unit from Summit.
      Dec 2008
      Salt Shake City, Utah
      Well since you got that one, now is the time to post a video of you using the thing!!
      How did your install go? I bought a LL and did not end up putting it in cause it was a little too over my head.
      Jul 2007
      Los Angeles, CA
      I won't get the piece until tomorrow. Hopefully later this week or next it should go in. I'll post pics then, still a bit aways from being able to demo the thing (still have a few things + electrical to do).
      Jul 2007
      Los Angeles, CA
      Here is some pics of the line-lock installed:
      Still have some minor adjustment shortening of the brake lines to get them away from the headers a bit.
      Bracket is made out of 1/8" thick steel that was polished and then powder coated clear. My first time trying the clear and I guess the heat discolored the clear or the steel a bit, now has a bronze tint to it, but actually looks very interesting.
      Jun 2006
      Katy,TX
      Slick bracket!!
      LI New York
      B+M here
