Thread: Remote IAC motor
03-28-2009 #1
Starting The Transformation
- Aug 2004
- 210
Remote IAC motor
Next week the tunnel ram base we will convert to an EFI manifold will be here. I already have the Accufab throttle body. Its based on the Lightening/Cobra part that is oval (5.5" X 2.625") and has 2 60mm butterflies. Accufab modified it for a single large oval butterfly (1700cfm). And Procharger has a cast aluminum 90 degree bend that has the same oval shape on one end and a 3.5" round on the other end. Have that too.
Still have one issue to iron out. This throttle body does not have an IAC build into it. So I will have to have one built into the intake manifold. Looking for some suggestions on what the best ways to do this are.
03-28-2009 #2
- Jul 2006
- Keller, Texas
- 250
http://www.electromotive-inc.com/sensors.html
Couldn't find any pictures to describe it, but usually you can mount the IAC valve remotely and justy run about a 1/2 inch line to the intake anywhere. Makes it easier than trying to hang the valve off a pretty intake. Google remote IAC and you will get a few ideas.Greg
1970 challenger convert-in process
1970 barracuda-driver
03-28-2009 #3
