    Thread: tranny jumpin!
      Oct 2007
      orange county, california
      tranny jumpin!
      so i just swapped a cammed LT1 and T56 into my 69 camaro and since ive never owned a manual or a very powerful car before im not sure whether this is normal.
      my transmission, when ever i floor it, moves a good 2 to 3 inches to the right. and not just gradually, it jerks it! I can feel it move and the whole assembly including the shifter jumps to the right and jumps back when i take my foot off the gas....
      im guessing this is not normal... any ideas as to what my cause this, cus its scarying the **** out of me everytime i drive my car!
      one other thing i noticed is that my drive shaft, where it connects to the tranny does not butt up against the tranny like i would expect it too, theres a good three inches or so of the part of the driveshaft that is supposed to be inside the tranny out there visble to the world... is that anormal amount. I had a shop make the driveshaft for me so i have no idea.
      thanks
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Walla Walla, WA
      Did you replace your motor mounts with the engine swap? If not, that's where I'd start.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Fontana, CA
      +1 on motor/trans mounts. I'd be afraid too.
      There is supposed to be some play into the trans needed during rear susp. bump. about 3/4"-1". 3-4 is way too much as the snout is only 6" in total.
      Nick R.
      Henderson,NV
      You must have a broken motor mount and you driveshaft is to short unless your looking a it with the weight off the rear axle.
      Todd
      Edmonton, AB, Canada
      Quote Originally Posted by 6'9"Witha69 View Post
      What 6-9 said. You need that 1" away from the back of the trans for suspension travel, but also to get the driveshaft into the rear yolk. If it was built to be flush against the extension housing at rest, you'd never jam it past the ears. Unless you're really determined...
      If you submitted the shaft measurements, you'll have to eat this one, but if the shop did it all on their own, I'd be asking for another one.
      Colin
      1950 Pontiac 12.82@105
      1999 GTP
      How about the transmission crossmember mount?
      good luck!
      Paul
