Results 1 to 13 of 13
Thread: BBC main studs vs. bolts
03-27-2009 #1
I have a set of ARP main bolts for my 540 but I want to run a windage tray so I will need to buy a set that works with the tray. Since I have to spend the money anyway can just get main studs or would this necessitate an align boring?
03-27-2009 #2If its been align bored already it shouldnt needed it again. If you havent align bored you want to have it done
Thall shall fear no amount of boost, For thy bottle is with me.......
03-28-2009 #3I think only the caps are a mated set, you can change out the bolts and not worry. I did that on mine, changed out 2 pairs of bolts for studs for the windage tray. I think Milodon had a windage tray stud set:
03-30-2009 #4
- Apr 2008
- Newark, OH, / Concord, NC
- 497
Windage Tray
The ARP bolts are a good choice, windage trays are 60's, you would benefit more by investing that money in a better pan with a screen, the best ones that I have seen are Stefs, they will work with you to give you the best pan for your application, you would just be wasting your money on a cheap pan so if you go for it, get a good pan otherwise stick with the stock pan with no tray
-Dale
03-31-2009 #5
- Aug 2007
- west michigan
- 514
