      T-5 worth it or worthless
      thinking of replacing t-10 with a 87 iroc t-5,car has a 450 horse big block.would this combo snap the tranny or will it hold
      Mar 2003
      Kirkland, WA
      I think it depends how often you want to fix your tranny. I managed to break the T-5 in my '83 Z28, which had a wopping 140 horse when it was brand new, and no where near that at 110,000 miles when the tranny broke. Personally, I wouldn't use a T5 in anything that made any kind of power.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      North Jersey
      If your big-block is making 450 hp, I can't even imagine what kinda torque it's putting out; probably over 500 ft/lbs. The '88-up World Class T5s are only rated to 330 ft/lbs. An earlier non-World Class is rated even lower. Maybe, if you don't use slicks, and don't powershift, and have a really good clutch, it'll last...a few blocks. LOL
      If you can get the IROC box for real cheap, you can get a rebuild kit from www.hanlonmotorsports.com and it'll take some abuse. Otherwise, look into a TKO 600. That's a very strong 5-speed.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Nov 2004
      Roanoke, VA
      T5+torque+traction=you walking. Dont waste your time on a T5 (hell, I broke a world class T5 with a N/A V6 just doing a burnout).
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      thanx guys i guess the t-10 will do for now and ill start looking at the tko trannies
      Encinitas, CA
      Take a look here for some helpful TKO information: www.ClassicChevy5Speed.com.
      Jeff Mortenson
