    Page 2 of 2 FirstFirst 1 2
    Results 21 to 29 of 29
    1. #21
      Newbury Park, CA
      That's nice!
    2. #22
      Jonesboro, Arkansas
      ooohhhhh, I agree..
      Carl Wilson
    3. #23
      Jul 2009
      Chicago,IL
      JamesJ that speedo looks awesome. I'm sold on that. Did you have a speedo you sent in or do they supply it for 300.00? What are you doing for a tach? Do u have the console gauges?
    4. #24
      Kansas City area
      thats a nice peace James!
    5. #25
      Newbury Park, CA
      You need to send in your old one.
      The tach input needs to be four cylinder. Redline can also retrofit a new VDO movement and tune it to get it just right.
      It is well worth the money.
    6. #26
      Northern MN
      Got an old 120mph speedo and idiot gauges on other side in 67 RS Camaro. Seems to me the way to go is mount two 5" tach/speedo in stock holes and get creative with smaller gauges in former stock SS spot.
      Has anyone done the swap new for older gauges without too many hassels?
    7. #27
      Newbury Park, CA
      I did that a while back, taking modern movements and retrofitting them to the original faces. In the end, I scrapped them since the stock faceplates do not have detailed numbers on them. The Autometer gauge pod offers better gauge options than the stock setup.
    8. #28
      Oct 2002
      Houston,TX
      Quote Originally Posted by Project Cortez View Post
      I sent them my factory gauge, looks like the only part of it they used was the face plate, if you called them they may have some extra ones...
      As for the tach, I am usning the factory one, I assume that my EFI box can send it the correct info for it to work fine...
      I also have the console gauges as well...
      James J.
    9. #29
      Newbury Park, CA
      The factory tach is set up for 8-cylinder. If you are using the factory ECM its' output works with a four cylinder tach.
