Thread: best st. pump with Hydroboost
03-25-2009 #1
- Mar 2005
- 467
Used several pumps now and still have a whine, even after bleed the bubbles.
Have a Hydratech hydroboost and a Saginaw with remote resevoir.
Can someone suggest a pump that works and puts out 3.0gpm .
03-25-2009 #2
- Mar 2005
- 467
OK did a little more footwork.
Called AGR and talked with Larry, very helpful.
Got a 1250psi 3-3.5 gpm TC pump coming.
Called Vanco Power Brake Supply, talked with Van, a lot of help and useful info. Vanco does alot of hydroboost stuff, apparently helped Ford with their hydroboost problems.
Van will look at my set-up and see if any problems with install.
03-25-2009 #3
