      Aug 2006
      optimum wheel / tire size
      Is there a size both diameter and width beyond which you are going for looks and not really getting anymore performance. Would be on a street car used for trackdays a handful of times a year. I always kind of thought anything over 18" and you are going after looks alone. What about width or is the wider the better?
      UK London
      There is a big debate going on over on another thread. The physics dictate that bigger is slower harder to spin and stop.
      I have compared the differences in wheel/tyres combo on my 2nd Gen '77 Camaro to 2000 and 2008 911 Porsche's. The '77 camaro is not stiff enough to take 20"s and ride well. A solid rear axle needs plenty of sidewall.
      Power and brakes can over come the increased moment of inertia and exploit the benefits of cornering due to stiffer sidewalls at the cost of ride comfort.
      I have a Porsche 996 911 originally on 18" with 265/35/18 tryes.
      upgraded to 275/30/19, lowered 50mm and the improvement was massive.
      I currently have a courtesy car 997 911 on 19" 305/30/19,stock ride height, definitely less performance on smooth roads. Faster over uneven roads. Not as good looking.
      The manufacturers are toying with the same issues, aesthetics over performance vs comfort. I'd suggest build your car for you, its as custom as you'll ever get!!!!!!!!!!
      Feb 2008
      i always say get the smallest wheel you can fit over your brakes.
