Results 1 to 17 of 17
Thread: Firebird rear
03-22-2009 #1
Firebird rear
So I have a 67 firebird with a 8.2 non posi and a 2 speed auto stock. I have changed the 2 speed to a 200r4. I just got a 8.5 posi from ebay not exactly sure what it is out of, I installed it this weekend.I swapped over all my brake parts they fit fine, had to change the u-joint no big deal. It is definatly narrower than my 8.2 by at least an inch. Does this sound correct? The drive shaft seems to be O.K. but I have heard some people say you have to shorten it. Is this true with all?
03-23-2009 #2It's probably a Nova 8.5. It will be 60 inches wide overall. If it uses the 3R u joint then it will be a '76 or later. You can find out what it is by the code stamped on the right axle tube.
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
03-25-2009 #3So I found out it is a 72 nova rear. I guess thats why they called them wide track pontiac. so do you usually have to shorten the driveline with this swap?
03-25-2009 #4It was my understanding that the driveshaft needs to be shortened by 1 inch when changing from an 8.2 to a 8.5.
03-25-2009 #5
