      UK London
      Limiting high rpm boost
      I'm very happy with my Procharged set up. But I would like some opinions on a this potential modification.
      Some petrol heads have with limited success installed waste gates and boost controllers post centrifugal compressor in an attempt to limit high rpm boost and increase low rpm boost. This results in a have your cake and eat it scenario, crazy boost off idle and you can still rev to the moon. If you use a roots or screw you'll get into heat issues.
      The main con with the waste gate method is the supercharger is still working to compress air that's being dumped by the waste gate making the whole combo less efficient than the correctly sized centrifugal for the same maximum boost with no bleed off. (Parasitic losses.)
      If a larger blower is used and restricted at the inlet then it will only work to compress the ingested air thus lowering total max rpm boost. Currently available restrictor plates are difficult to change over.
      If we could introduce a variable electronic restrictor pre-compressor and control its attitude we could map the curve to give constant boost fromm 500 rpm to 7000 rpm if the blower were big enough.
      I wish I had thought of this before.
      1) SBC at 350 - 400 CI.
      2) F3-A 117 Procharger head unit at 2800 cfm or 2100 hp with 5.5" inlet.
      3) Electronic valve like the electronic QTP 4" cut out modified to 5.5" and geared to move fast enough.
      4) Controller calibrated and mapped to adjust the valve to show contant boost. And adjustable from the cockpit like the Turbo boys!!
      Lastly to further refine this imaginary product we could build in a pre compressor methanol injector bracket.
      Just an added feature to enable the blower to act bigger and cool down the charge as well. Originally used in WWII on German fighters just like superchargers and nitrous oxide. If injected in a mist from a correctly sized nozzle it will vaporise before exiting the supercharger and not puddle in the intercooler if present.
      Any comments welcome.
