    Results 1 to 10 of 10
      Jan 2007
      SOCAL
      hooker ls1 swap headers, PICS
      So I will have to modify a bit. Did not use thier full kit, just the headers.....the pass. side hits the control arm and the driver, the steering box...
      Should I just heat them and tap them a bit or cut and reroute?
      D
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Why don't you use their engine mounts? I know it's a bit more difficult to get everything to fit with the Hooker mounts but once done, the headers fit with all the room in the world and the engine/tranny are sitting as far back as possible which is really good for balance.
      Jan 2007
      SOCAL
      I shoud have. I made my own off the ATS template. I pushed the engine back 2.5 inches for 50/50. I took a torch to them. Pass. side fits, little more heat and banging tomorrow and it will fit.
      They tuck nicely.
      May 2007
      las vegas
      on the passenger side where it hits the control arm make sure you clearance it enough because when you align the car they will be shimmed out towards the headers again.
      AJ
      1970 camaro rs, z28:pro-touring?... i wish
      93 trans am
      Jackson Ms
      why buy headers to beat on? it makes no sense to me. it kills the performance and hurts the looks. just use the right mounts
      Chris V
      SOLD
      Apr 2007
      Huntsville, Tx
      I had no clearance issues with my hooker headers. 69 firebird, carshop engine adapters, small block engine mounts.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      Newbury Park, CA
      Dustin will be running a roots-type supercharger, and hence cannot push the engine too far back due to belt interference with the firewall. It also cannot go too far forward and up or else the throttle body will hit the hood. The ATS plates place the engine almost perfectly for this application.
      Sam
      I heard carshop's plates like s&p. but they have second version also which is more close to firewall. I wonder whichone you have. Bec. I have the s&p's.
      67 Pro-Touring Camaro
      ISMAIL
      Walla Walla, WA
      I'm doing an LSx swap myself right now and have been looking at a lot of the plates out there. It seems to me that the plates that use the lower forward bolt for both the three bolt engine mount and the four bolt plate must ALL locate the engine in the same place lengthwise and vertically in the engine bay. The only mounts I've seen that I recall right now off the top of my head that don't do this are the Edelbrock mounts, which move the engine back from the mounts that make the bolt do double duty.
      A sticky thread detailing all of the plates would be pretty useful.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Apr 2007
      Huntsville, Tx
      Quote Originally Posted by 67LS1T56 View Post
      Sam
      I'm not sure which plates I have. I got them almost 2 yrs ago. They only had one plate to choose from them.
      Sam
