      Jul 2007
      Hydroboost issue MC wont work
      I have a hydroboost system from a Astro van I am installing on my 87 SS. I have a 1-1/8 Mid 80 B-body MC. The bore is too big. It will not fit this unit. What MC should I get? I currently have 13" C5 Fronts and 12" LS1 Rears.
      87 Monte Carlo SS 408 LSX S482 Holley EFI 4L80e
      92 GMC Typhoon Built 4.3l Vortec Heads Baby Billet 25G Turbo
      09 G8 GT Built LS2 CNC'd LS3 Heads
      Morehead City, NC
      Quote Originally Posted by awdvette View Post
      I recently built a very similar system. Same brakes with hydroboost. Used a master for a late sixties to early seventies Corvette with four wheel disc. I believe it is 1 1/8 as well but works flawlessly. Cost approx. $90.00 at Carquest. This is a new not rebuilt MC.
      Mike
      Jul 2007
      Will this Wilwood MC work pn:260-4894
      Oct 2006
      Norway
      S10 master and machine it to fit the hydroboost. Take a look at my Cardomain site.....
      Feb 2008
      Staten Island, New York
      dumb question why can you use the master cylinder from the s-10
      Oregon
      Quote Originally Posted by maldo View Post
      You machine the pilot register on the mating surface of the 80's S10 master cylinder to match the standard 37.5mm [1.476"] diameter found on most mid-size GM car brake boosters. This gives you a quick take-up master cylinder with a secondary bore size of ~24mm [15/16"] and a much larger primary bore (31.75mm or 36mm depending on whether you use one from a manual or power brake application) resulting in a high, firm pedal that still generates adequate pressures without the pedal travel length associated with most straight 7/8" or 15/16" bore installations.
      I think the modified S10/C10 units tend to be more popular than say the 3rd gen F-body units because they have SAE ports on the driver's side and a relatively flat reservoir, whereas the F-body has metric ISO ports on the passenger side and a very angled reservoir designed for a steep installation to clear the inner fender well.
      Tobin
      KORE3
      It's what I does.
