    Results 1 to 14 of 14
      Houston, Tx
      Complete Budget Friendly EFI - Thoughts?
      Hi All,
      I wanted to get some input on the following system.
      Total Cost ~$2200 for all new parts. I could probably be closer to $1500 if I shop around for used.
      Fuel System:
      Fuel Tank - Spectra EFI Tank
      Computer:
      MegaSquirt Computer - http://www.diyautotune.com/catalog/m...ase-p-171.html
      Manifold:
      Holley Stealth Ram: http://store.summitracing.com/partde...5&autoview=sku
      Fuel Rails:
      Holley Fuel Rails - http://store.summitracing.com/partde...5&autoview=sku
      Injectors:
      42lb/hr Fuel Injectors - http://store.summitracing.com/partde...5&autoview=sku
      Throttle Body:
      58mm LT1 Style - http://store.summitracing.com/partde...5&autoview=sku
      Mass Air Flow Sensor:
      Granatelli - http://store.summitracing.com/partde...5&autoview=sku
      Distributor:
      Mallory EFI Distributor - http://store.summitracing.com/partde...5&autoview=sku
      Houston, Tx
      I plan to swap all the parts with used if I can find them and will likely save close to half on the Throttle Body, maf, injectors and Distributor
      Kettering, OH
      Are you including a WB 02 and wiring harness? You'll need a regulator, filters and assorted plumbing too. Last, most of these systems require a spark box, you may need that too.
      Houston, Tx
      Quote Originally Posted by Hammered View Post
      Sorry... Already ordering an innovate motorsports LC1 Wideband o2. I need to get TPS, etc. Need to also think of all the plumbing hardware like you said. Oh - and the fuel rails have an integrated regulator
      Oct 2007
      For the extra $300.00 bucks I would go with this
      67 Camaro In progress
      Feb 2008
      Close to how I was originally going to go with my engine, here are some thoughts.
      Consider building your megasquirt. While I would highly suggest also building a stim tester that's another 50$~, it was not hard at all and I had never built any electronics before. Almost certainly even if you buy it complete you will have to open it up and set it up for your application so why not just do it all and save 100$+. Also remember to add in the tuning cable.
      As you said, throttle body and injectors much cheaper used.
      You don't need the MAF, the Megasquirt uses a built in MAP sensor, so remove that.
      You can drop some if you get a converted LT1 Gen 2 intake. Here's one for 225 with fuel rails for example although they are 400$ usually I believe.
      https://www.pro-touring.com/forum/sh...ad.php?t=49780
      The holley is what I was going to use but the fuel rails are ridiculously expensive.
      a few more things
      Holley Stealth Ram you can pick up used on eBay quite often. I would personally look to get one with the throttle body from Holley as well. You will need the IAC. Other things to think of:
      wiring harness will run around $500 to $700. You'll need to likely fab something for throttle (and kickdown depending on tranny choice). Fuel filters (pre and post) and fuel lines--you can spend anywhere from $100 to $1000 (litterally for the billet/braided stuff from Aeromotive so choose wisely here). You will need bronze gear for the distributor if you are running roller cam and that distributor has the small body meaning you need external coil (don't think you need spark box though). You can save on distributor by buying used from TPI.
      Are you building 350 or 383? If 350 depending on how big heads and cam are you may consider the smaller throttle body (52 mm) as you will be more responsive on the street and doubtful down any HP on the top end. The 58 can bog a 350 down and make it a lot less fun to drive on the street. If 383 strip principally or really big heads and cam then the 58 is a good choice.
      Also i would not buy used fuel injectors--buy these new and flow matched. Accell makes great ones that are not expensive.
      I would also run a fuel pressure meter, add that to your list for safety's sake. You may also look into a knock sensor if your ECU supports it.
      Also don't forget gaskets, they can add up. And you'll need some kind of piping for an intake, best to get it toward the front of the car away from hot engine and put a cone-style K&N filte on it. Another $100 or so.
      Lastly no dissrespect to Xlexus but i think there is a dramatic advantage in terms of the broad torque band available and improved fuel economy with the plenum design like the TPI/LT1/HSR over a throttle body injection. I would personally not go through the trouble of installing EFI and use a TBI. There is a reason the OEMs went away from TBI designs so quickly IMHO.
      Good luck!
      Paul
      Keller, Texas
      Quote Originally Posted by Chevy View Post
      Good luck!
      Paul
      The system he showed had a carb style throttle body, but was port injected. Much better than a old school TBI with two or four massive injectors above the throttle body.
      I have done astealth ram before and made my own injector rails. The bare manifold is real cheap, throttle bodies readily available, and rail stock is cheap at $10 a foot. I used a regular drill press and rented the injector bit from Kinsler to make the injector holes in the fuel rail.
      I have never used a megasquirt, but used DFI setups can be had for about a grand for ECM and harness.
      Greg
      1970 challenger convert-in process
      1970 barracuda-driver
      I am running a megasquirt with a stealth ram and a wide band o2. The tuning is really easy with megatune. It will make all the adjustments for you based on the afr you enter into the set up. I bought a lot of used stuff on ebay for not much. I am as green as grass when it comes to EFI and had very little trouble getting it to run and run well. The nice thing is 10 degree starts without pumping the crap out of it to keep it running. I am not using the ignition side yet but will be very soon.
      Houston, Tx
      Quote Originally Posted by keith1365 View Post
      can you share your fuel system with me?
      Jan 2007
      Royal Oak
      Have you looked into an Edelbrock Pro-Flo setup used? I got a complete setup for less than 1200 on ebay. Easy to install, and great support from a reputable company.
      Harriman, Tennessee
      I think this will depend on the cam. The Crane roller hydraulic cam i am running in my BBC came with a specially treated gear on the cam. Melonized maybe? in any case, you can run a standard distributor gear with it.
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      I used the stock tank and pickup. I took the stock pickup system out of the tank, drilled a 3/8 hole in a spot that was out of the way of eveything else and brazed a piece of 3/8 stainless tubing into the tank to use as a return. I then used 3/8 alum tubing and ran 2 lines to the engine compartment. I found a fuel pump off of a friends dead porshce 944 which is just a bosch pump. I mounted this on the inside frame rail using rubber mounts. In the engine compartment I ran some braided lines to the stock LT1 fuel rails. They fit on the stealth ram but you need to make a fuel line to connect the two banks as the stock plumbing will not fit. I ground the ends off the rails and welded some fittings on the end of the rails and used braided line to hook everything up. Used the stock LT1 fuel regulator. I do not have much money in the system and have not had any problems with it. I keep the tank at least 1/2 full if going around corners hard but have not had any fuel starvation issues so far.
      Feb 2007
      USA, TN
      Quote Originally Posted by ProTouring442 View Post
      Shiny Side Up!
      Bill
      If you are running a stock Chevy roller cam, a melonized gear is all that is required. A take out distributor from many GMPP engines will have it. Comp Cams sells a .5 inch one as well. They are not expensive.
