      Medford, OR.
      Power to Man. 79' Firebird (Help)?
      Hello everyone,
      I am working on a 1979 Pontiac Firebird with 15" Rally Wheels and will be converting from Power to Manual(Header and engine space) and I am trying to find some type of Bracket or Brace to reinforce the firewall so then when brake pedal is depressed there is no flex!! Can anyone of you guys send me the right direction or source, or part#
      Many Thanks
      Out West LTorres
      Pittsburgh, PA
      Master power...
      LTorres,
      Master Power makes a bracket that bolts to the existing 4-bolt (booster) pattern and has 2 studs centered so your manual master sits in the center of the firewall hole. It also helps reinforce the firewall. Look under the accessories section of their site.
      Hope this helps,
      Shane
      Medford, OR.
      Thank You
      Thanks man. I knew someone would have a source or INFO. Thanks again!
