03-13-2009 #1
- Aug 2004
- St. Louis
- 191
Brake Line Routing Question -First Gen
I'm converting from a CPP Front Disk/Rear Drum set-up to a C5 set-up from Kore3. I'm sure Tobin can answer the question but don't wish to bug him tonight.
I have a quick question about brake line routing on the front.
Currently my front brake lines each connect seperately to the front of my proportioning valve, which hangs directly under the master cylinder. I'm trying to keep the appearance of this installation clean, so with that said do I run a single line down to the frame and create a "Y" junction of some sort, and then run feeders to each left and right front brake assembly? I'd rather not have the junction directly under the master cylinder unless it compromises performance.
Please advise
