      Jun 2008
      Hammertone paints
      i am looking to touch up some bits and pieces on my car and was thinking about using a hammertone paint finish... not a two part process but the rattle can type.. anyone use them ?
      exactly how durable are these finishes....
      Dublin, CA
      They are Ok, I used some in my trunk and it held up fairly well until I tore down the car again. Like most of those type of can paints it is a bit plasticy if sprayed too thick.
      Brent
      1971 Camaro, LT1, 4L60E
      I have used the non spray bomb kind and sprayed it, used it on my fan shroud and it seems to be a good paint. Finish is different but in a good way. I would use it again but like I said this was the non spray bomb type from Lowes.
      1968 Camaro Crossram EFI 385, TKO 600 fully REMed. 594 hp/576 tq-ft. ATX spindles, Speedtech control arms, Chassis Works G-Link on 12 bolt with REMed gears, Chassis Works mini tubs, 245/40-17 front, 335/35-17 rear.
      Nov 2001
      Sacramento Ca
      it holds up very well. I've used it before. I've also used wrinkle paint. Wrinkle paint is extremely durable.
      Tony Langlois
      1966 Corvair Monza
      Harriman, Tennessee
      I have used the Rustoleum (sp?) brand of hammertone quite often. Looks great, and seems to be very durable!
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
