    Results 1 to 12 of 12
      Jan 2009
      so cal orange county
      Body mounts rubber,urethane or aluminum
      Which ones work best I'm redoing an a-body for street and track days.
      Let me know which work best noise is not a big factor with loud exhaust system.
      Auburn, WA
      Personally, I like aluminum mounts. NVH increase isn't noticable IMO.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Sep 2002
      San Jose, CA
      Aluminum, the less flex; the better.
      Just call me Brett
      Jul 2007
      Los Angeles, CA
      Yep let the suspension do its work, don't let the body to sub-frame move around.
      USA
      Solid / aluminum.
      Jeff Tate
      U.S.A.
      OK, Al, but...
      what brand? Pros/cons.
      Do you get the lowering ones? If so, anything you need to keep an eye on?
      thanks,
      Paul
      Nov 2002
      state of confusion
      Full-frame car - anything that's frame-mounted and either runs close to or also attaches to the body. Or between the two where there already may not be a lot of extra room.
      Clearances above the bellhousing and tranny
      Possibly clearances above the driveshaft, engine, and radiator
      Steering column alignment
      Brake lines
      E-brake cable
      Linkage from the clutch pedal to the Z-bar (if present)
      Throttle linkage (if not a cable)
      Arrangement/fit-up of the exhaust and its hangers
      Fuel lines
      Tire clearances
      Edit - speedometer cable
      Norm
      Gone but not forgotten dep't:
      Jan 2009
      body mounts
      Looks like the aluminum wins I will have to look up the person who sells them in the classified section.
      USA
      Detroit Speed manufactures and sells them.
      Check around to see what vendors have them for a good price..
      Global West manufactures and sells them too.
      Global West sells them direct , but the same product ( Genuine Global West ) is cheaper through Year One.
      Global West had them on sale a few months back on their website ...
      The lowering ones may cause clearance issues with the transmission , fan shround , exhaust , speedo cable , etc...
      I would stick with the stock height.
      Edit :
      Woops , You have a Monte Carlo !
      I'm not sure who makes them for a Monte Carlo...
      Jeff Tate
      U.S.A.
      Feb 2006
      Somewhere in the Pacific Ocean
      None of the companies make them for A-bodies. Here is a link to someone that is selling some.
      https://www.pro-touring.com/forum/sh...ad.php?t=53224
      Goodwin
      Red Deer, Alberta, Canada
      Anything that lowers the body on the frame will cause you some headaches. Namely the rear shock crossmember. Theres already little room to get in there, let alone lowered body mounts.
      The link posted about is a smokin deal!
      Matt
      Instagram: Cst_koon
      So. Cal.
      Im for the solid mounts too. Umm, I would just make them, simple turning there. Got a lathe? Thats a quick job. And I would stay with the same thickness, no need for lower spacers. JR
