      Feb 2006
      East Aurora, NY
      bronze pilot bearings
      Would it be bad to use a bronze pilot bearing in a TKO 600 application? I used one in my own car (which has not been fired yet), and have heard that warranties on these transmissions are void if the roller bearings are not used. I have had roller bearings go bad when used with the muncies, therefore at my shop we only use the bronze pilots.
      Dave @ Camaro Specialties
      http://camaros.com/
      Aug 2001
      Connecticut
      I'm with you on the bronze; less to go wrong. Kind of odd that they'd void the warrantee though, maybe just on scoring of the input shaft? -Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      USA
      There is a little more clearance in the Bronze bushing as opposed to the roller bearing.
      It could theoretically allow for too much radial run-out in the input shaft..
      Use the roller bearing.
      Make sure to face it the correct way when you install it.
      And , if you have trouble getting the transmission to go into the bellhousing , PUSH IN the CLUTCH ARM while pushing the input shaft into the pilot bearing.
      I tore up TWO pilot bearings when I installed my TKO.
      I was gonna use the bronze bushing because I figured it was more durable.
      But I called Jim at Classic Chevy 5-speed and he explained how to get it in by releasing the pressure on the clutch while "gently" pushing the trans into the bellhousing.
      So , if your reason for using the Bronze is an installation problem , then that's why..
      Hope this helps..
      Jeff Tate
      U.S.A.
      if you are worried about blowing up the needle bearings then your not sure about your alignment
      im running a bushing right now with my 600 because i went through three needle bearing ones i still think its my fault that it just wasn't properly aligned in the first place
      by the way you will know if its good to go when you try and hit third gear hard at anything over 5000 it will either bind or go right in
      (by hard i mean no letting off the gas just clutching and grabbing)
      good luch
      josh
