    Results 1 to 16 of 16
      Jan 2009
      90 Accord will not start
      Got a mystery here.
      Changed the oil, spark plugs, wires, cap and rotor, and valve cover gasket on my sisters 1990 Honda accord and now it will not start.
      Cranks over strong, every plug has strong spark, fuel pump is working, I pulled off the main fuel line and had fuel spray out into a can when i turned the key on, and i can smell gas fumes out the exhaust after i crank it over.
      Wont even start when I spay starting fluid into the intake. Doesnt even sputter.
      Searched the net and found a common problem with the Main Relay but i pulled that out and it tested fine from the directions on alldata.
      When I first pulled out the old plugs they all had oil around them from bad spark plug tube seals. which is why i replaced the valve cover gasket. Is there any way that small bit of oil getting into the cylinder when i removed the plugs could be the problem?? I pulled out all the plugs and cranked the motor over for a bit to see if i could blow any oil out but still no go.
      Any help would be great. I started this on sunday and have been pulling my hair out every since.
      Dave
      change the main relay! If screws w /the ecm w/intermittant failure, also, check the small grounds to the valve cover
      May 2002
      Northern California
      double check that cap to coil carbon. Very common to crack it. You might see spark but it might not be enought to fire the plug.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      USA
      I worked at an import shop in the mid 90's.
      We saw Honda after Honda with defective "brand new" rotors.
      The plastic was too porous and they either wouldn't fire or skipped badly.
      So , double check the ignition rotor.
      Substitute the old one just to see.
      Jeff Tate
      U.S.A.
      Rural Retreat,VA
      If it is not getting injector pulse it will not fire. Check inside the distributor cap to see if there is any oil. There is a hall effect switch under the rotor button that signals spark and injector pulse.
      Sep 2007
      May sound silly to you, but did you put the new rotor on pointing in the same direction as the old rotor? I teach auto at a high school and you would be amazed of what can accidently happen.
      ED
      NW Burbs, IL
      Well it was running before you made the cap + rotor swap right? I would look there.
      FYI, the main relay, or fuel relay, under the dash will “click” twice when working properly. I have a 92 accord and chased this little bugger around for months! It is usually a intermittent problem:
      http://www.alldata.com/techtips/2003/20030602c.html
      Is it throwing any codes?
      evansville, in
      i had same thing happend, ended up being ign wrong key! i was useing a key that didnt have the chip. sounds like BS but its true
      NW Burbs, IL
      Quote Originally Posted by 6994lt1 View Post
      A 90 does not have a chip.
      Sep 2007
      I happened to stop at the auto parts store today, it is impossible to install the rotor 180 degrees out. Did you possibly confuse the firing order? If you want to rule out fuel, just spray starting fluid into the throttle area, if it still does not want to start then it is not fuel.
      ED
      Mountain View, CA
      Burn it and buy a new Camaro. It's the patriotic thing to do.
      True T.
      My blog
      USA
      Quote Originally Posted by Damn True View Post
      Funny !
      Jeff Tate
      U.S.A.
      Oct 2008
      Durham,NC
      if it is a main relay you can normally beat on the side of the drivers dash hard and it will crank 75% of the time. i would check the coil itself due to the fact when they get over heated they tend to fail and you can see it on the side of the coil where it has got hot ( metal cover you will have to pop off possible to see). i do believe you got a main relay or a coil problem though. the oil you are talking abou is from the tube seals 50% of the time but there is more to it then just but you might wanna pm me on that part. when it does fire up it will smoke like hell for a few mins due to oil in cylinders that drained be advised lol. when you cranked it did you hold down the gas and try cranking??? let us know
      evansville, in
      Quote Originally Posted by bochnak View Post
      oops! sorry. your right as you well know, it was an 03 i think. the company i work for has about 20 hondas as fleet cars dont know how many dodge and ford trucks. i hate them all
      Holmes Hollow, Ontario Canada
      I drive a 93 with 426 000 kms. I know the relay you are talking about but if it was the relay why wouldn't it have been a problem before he made the changes? I know this is going to sound seriously stupid but if its a standard, try bump starting it and let the clutch out enough to make sure the crank has moved postion a bit. Then try starting it again.
      ____________________________________________
      Scott
      Oct 2008
      Durham,NC
      temt is what mess with the main relay alot of the time you crank it up in the cool morning drive to work then get off at 4 and it is hot as hell then no crank! whoa it cranked this morning. we are throwing opinons out i would have reinstalled the old parts alredy to see if it cranked up. hondas are touchy with aftermarket parts so use factory parts buddy!!!!
