    Page 2 of 2 FirstFirst 1 2
    Results 21 to 22 of 22
    1. #21
      Dec 2002
      Lost Wages, Nevada
      Same thing... all that does is inject oil into the system... but does nothing to get it out.
      The problem isnt with delivery... it's with the extraction. What you end up with is all the oil in the pan (which is a windage problem) and you don get it back to the tank fast enough for it to properly supply the pressure side of the equation.
    2. #22
      Jun 2006
      NW burbs IL
      Now I'm confused, I thought the initial problem was getting the oil to drain back from the upper end. And if to much oil stays up top in a high rpm or high G situation the pickup may suck air. Now if you enter a pan that has more available oil it should take longer, albeit not much longer, to suck the system dry. Any idea on how much oil can be suspended with a severe windage problem? or how much the LSX engines hold up top when pushed?
      edit: After rereading your post I'm starting to understand. Although if its a windage problem how will a dry sump prevent that? wait: is the definition of windage when the rotating assy not only whips the oil into a mist but also pulls, or almost creates a vacuum pulling oil up from the pan?
      Matt
