      Milwaukee, Wi.
      Nova dash removable?
      Like the title says, is a 68-72 nova dash removable?
      We are planning a 10pt cage and want to go through the dash. We are thinking it would be easier this way.
      Any help would be appreciated.
      Steve
      Lawrenceville, Ga.
      Anything is removalble with a airsaw ........
      If your intent is to get the tube as close to the windshield piller than by all means remove the dash via airsaw. Then fit it back in around the tubing & then reweld it in.
      This will be key if you intend to run a knee tube. You can hide it up & behind the dash.
      I would leave about an inch up on the windshield lower area to sew it back on. Remember to cover the glass as weld splatter will ruin the glass.
      You could also make the dash dzus-able so as to get at anything you've hidden behind it.
      Good luck & post up some progress.
      Ratty 46
      Milwaukee, Wi.
      Thanks for the reply, I was hoping to hear you can unbolt it!
      Steve
