      Jan 2009
      New Mopar guy needs wheel info
      Hello all!
      This is my first post on this totally cool site.
      I am currently looking to install some wheels on my 67 plymouth belvedere. I would like to use the new torq-thrust m anthracite colored wheels in 17" diameter by 8" width. Does anyone have any backspacing/offset recommendations for me?
      Your advice is appreciated.
      Nov 2007
      Quote Originally Posted by mrn2obelvedere View Post
      Hello all!
      Some ideas here
      http://board.moparts.org/ubbthreads/...ue#Post5031561
      IMHO,
      17x8 5" backspacing 245/45/17 Front
      17x8 5" backspacing 245/45/17 or 255/45/17
      With 17" rims you can run up to about 5.6" backspacing in the front with the flat style upper ball joints, and the stock later style disk brake spindles. I think you could run a 17x9 5.6" backspacing with 275/40/17 up front. You will probably have to fold or cut a 1-1.5" by 3" triangle out of the bottom of the front fender wheel lip.
      66-67 B-bodies in the front: can take a 225/60/15 15x7 rim with 4.25 backspacing (cop/rally rims). As a coincendence, that's the max on my 68 Barracuda also.
      In the rear there are guys that fit 275/60/15 on 15x7 4.25 backspacing. I think that with wheel lips rolled. So you should be able to fit 275/40/17 on 17x9 and 5.0" backspace in the rear too. But still make measurement to assure backspacing.
