      Kiler wisconson
      496 BBC on ebay ???????
      Buddy of mine is looking into buying a 496 Bigblock on ebay..
      it has 640 FT lbs of torque and 530HP..
      it only has a performer intake and world merlin heads and 10.3 compression..forged pistons, forged crank, roller rockers and comp cam.
      HOw is it they can sell this motor for $4000 with a dyno sheet...?
      Sounds way cheap.. with quallity parts..
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      Probably cast crank, not forged. Blem heads. Dyno'd one engine and just copy that sheet and send it out with every engine that's built the same.
      Nov 2004
      NW Arkansas
      Quote Originally Posted by gauder
      that sounds like a good guess to me :icon_razz
      KENNY DAVIS HOTRODS
      Aug 2003
      I have a 496, Canfield 310s, 8.5 compression, 246@50 cam, makes 540 / 575 real power. With 10 to one, 640 is close if it has good heads. With all that said, It takes $4000 in the top end.
      I have been looking at small blocks on ebay and have come to the conclusion through a nights worth of research that with 100s of listings very few actually seem to sell. Not to mention one seller has over 30 listings for complete engines as of 3/8/05.
      The guys that are selling engines, 1-4 per month, are listing anywhere from 2-5 at a time and maybe selling 1 of them. Then relisting the unsold engines again.
      Kiler wisconson
      It has a SCAT crank.. I beam rods,.. Oval port merlin heads... with 2.19, 1.88 valves
      Project JUST-N-SANE
      Scat makes cast cranks as well as forged, some i-beam rods are only rated to 500hp and if you look elsewhere on e-bay you will see many "factory seconds" of Merlin heads for sale.
      Just be warned and remember the old saying-------> "How fast you want to go depends on how much you want to spend".
