      Oct 2007
      68 Camaro Project question
      If I purchased a wrecked ls1 camaro, would it be possible to swap out the engine and including the air conditioning unit to a 68 camaro? Has anyone done this? I know you can swap the engine. I was curious about the a/c. Thanks
      Aug 2005
      Hamilton, NJ
      It's been done a lot, search a bit.
      To leave the AC comp in the stock 4th gen location you have to notch the frame.
      Scott from NJ.
      Vent Windows Forever! ...
      Felton, DE
      http://ls1tech.com/forums/conversions-hybrids-28/
      Start reading. It can be done but i have never done the AC part so i am not sure whats involved with it.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Dunwoody, GA
      Are you referring to the evaporator and main box that sits behind the dash? If so, it may not be very easy. There's a 73 Trans Am that used the fourth gen AC unit and it required heavy modifications to the firewall to make it fight. Yes, the 73 is different than the 68 but I'm betting it's not that different.
      Trey
      ~ Jon Hammond
      Oct 2007
      That's the answer I needed. Not looking to do heavy mods for an A/C. Looks like Vintage Air for me!!! Thanks
