Results 21 to 24 of 24
04-21-2009 #21
Not exactly sure where this build will end up since I have so many ideas floating around in my head. That's why I chose to call the car "Evolution". As I complete each stage, I will then decide where to go with it next. I have been researching some of the mods you mention and would love to do them all but the budget it tight for now. Hopefully as time passes that will change and allow me to go a little more crazy with the mods. You're right about the car being very clean and since it no longer has its original motor, I don't feel bad about modifying it to my liking.
Nick @ MWCC
Full Service Restorations For Classics, Muscle Cars, Street Rods, Customizing & Fabrication
419-523-6900
www.m-w-c-c.com
04-24-2009 #22
- Feb 2006
- 52
most of the mods i posted for you are 'junk yard' style mods that can be done cheaply. ie the vette calipers and brackets are fairly cheap on ebay and the 3rd gen rotors are next to nothing at the junk yard. welding up your frame is labor and gas only. welding up some home brew subframe supports are the same. some are expensive no matter how you do them ie setting up a rear end... modding your 10 bolt (disc brakes, posi, c-clip eliminated, beefy axles) will cost you the same as buying a 10 or 12 bolt pre set up (about a grand).
the best way to keep it cheap is to do it yourself and dont be afraid to fabricate instead of buy.
a word of cation though... i would figure out how much you can spend every month on your car. if you plan on driving this thing while you are working on it, your slow upgrade plan might work. if you want to 'build it right the first time' and not buy the same parts multiple times it might be better to make a list and buy parts in a planned order. do suspension and brakes first, then drive train, then engine and paint last. most guys do engine first and end up with 500+ hp and 1970s brakes and a broken ring gear.
a lot of people on this forum have deep pocket books which definitly helps with a hobby like this... I will never bash a guy who spends big bucks to have a car built because I might be that guy someday. however my favorit builds are the ones where the guy picks up a welder and and some scavanged parts instad of the phone and a check book.Last edited by newby; 04-24-2009 at 06:00 AM. Reason: yeh
04-24-2009 #23No Decals
I took the decals off today and took some new pics. I also painted the wheels body color. It was pretty sunny today so the metallic on the model is real apparent. The finished car will not have as much metallic. I had to spray very thin very light coats so not to melt the plastic. The reducer in the base color would melt the model if I sprayed it as I would the car. When you do light dusting sprays with metallic paints, you get a lot of metallic. Anyway, the car looks good without stripes too. I may throw a pair of '70 Z28 grille emblems on the fenders when shes all done. Let me know what you guys think now that you can see it without the stripes.
Nick @ MWCC
419-523-6900
www.m-w-c-c.com
04-25-2009 #24love bodycolor wheels.
i'd keep the stripes tho. i just like'em.
color could change tho.1982 Grand Prix LJ: 3.8~T-top~buck/con
1986 Grand Prix LE: 5.0~T-top~buck/con~over 35 extra cost options~you could say it's LOADED.
