    Results 1 to 11 of 11
      Jul 2007
      Los Angeles, CA
      Sacrificial Anode?
      Anyone know where to get a 1/4 NPT zinc sacrificial anode without brass fittings on it?
      The only one that anyone seems to carry is the Flex-a-lite one that has a brass fitting on it (running a aluminum. radiator).
      http://store.summitracing.com/partde...part=flx-32060
      I have seen the caps with them built in, but really looking for an anode that will fit into the drain at the bottom of the radiator.
      Thanks!
      Newbury Park, CA
      Do you want one with a different material NPT thread? What is wrong with the brass part?
      http://www.mcmaster.com/#sacrificial-anodes
      Walla Walla, WA
      Where do people install these things? I've got one, but I don't have a hole with 3" depth behind it on my SBC.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Jul 2007
      Los Angeles, CA
      I thought brass fittings in an aluminum radiator were bad? Least the tags that came with my Ron Davis radiator say not to use any brass fittings.
      Thanks for the link. Looks like I have 3-1/2" of depth at the drain plug so that 1/4 NPT that is 3" looks perfect!
      Newbury Park, CA
      Break out the hacksaw Mike. I used then in the heads of my old 406 since it was an iron/aluminum engine.
      What does RD recommend using if brass cannot?
      Aug 2005
      Hamilton, NJ
      Can I use a cutoff wheel?
      LOL
      Scott from NJ.
      Vent Windows Forever! ...
      Walla Walla, WA
      Let me bring on the tech Mike.
      Hacksaw.
      ROFL. Thanks
      Jul 2007
      Los Angeles, CA
      I dunno they didn't have a specific recommendation when I asked them.
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      Most of your aftermarket aluminum radiators have a brass drain petcock on them.
      I have used these anodes before with no issues.
      Feb 2009
      So-Cal
      I have a ron davis radiator and I put the flex a lite anode in the drain petcock. I think it should be in the radiator because that is what you are saving from the electrolysis, but you can put it anywhere. Voltage will always take the path of least resistance.
      It is always up to you.
      James Faria
      07 GT500 740rwhp
      Southern Indiana
      As for me arfter spending hundreds or thousands on aluminum heads, rad etc, go look at Evans Cooling NPG+ and NPG-R Non-Aqueous Propylene Glycol coolant, with a 375 degree boiling point at atmospheric pressure, and it has no water which will negate the corrosion issue.
      Yeah its pricey but hey isnt $150 in coolant worth proper cooling?
      Used it in several projects and it will cool very well and have yet to see any type of corrosion issues. http://www.evanscooling.com/index2.html
