    Results 1 to 9 of 9
      Janesville, WI
      Battery saver product name???
      I'm trying to locate a product I remember seeing. It connects to your automotive battery and disconnects power to the car if voltage gets to a certain point. This way you accessories cannot drain your battery to the point the car will not start.
      Does anyone know what I'm talking about? Googling is coming up with products that plug into the cigarette lighter. I want the product that goes right on the battery.
      My work car has a lot of drains and if it sits more than a couple days battery is dead to the point the power locks do not even function. I have no choice on all the electronics on the car.
      Please, let me know if you know the correct name for this.
      Thanks in advance!!
      -Shaun-
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
      Erie, PA
      Search for "battery Brain"
      Andreas
      www.fgmcc.com
      May 2002
      Southeastern WI
      battery Tender.
      Jeff
      Janesville, WI
      Quote Originally Posted by FULMNTE View Post
      That is exactly what I was looking for! Thank you.
      Any experience with this brand/product?
      -Shaun-
      -Shaun-
      Aug 2006
      Las Vegas
      Quote Originally Posted by subtlez28 View Post
      -Shaun-
      I have had 3 of them and they work great. Get the platinum one. It comes with a vibration sensor that doesn't allow it to be disconnected while the car is running and a remote battery connect/disconnect as well.
      I actually used it in a C6 corvette that I switched the water pump to electric and hot wired the fans to run both between drag runs at the track. I have one now on a 72 z28 for theft protection and to assure a startup.
      They have all worked flawlessly for going on 3 years now
      Aug 2003
      I have some battery Tender Jrs for $30 + $5 shipping
      Janesville, WI
      Thanks dsapper.
      Also, for anyone who is also in the market, I found this:
      http://www.prioritystart.com/
      More simplistic, so that could be better or worse depending on your needs.
      -Shaun-
      Aug 2006
      Las Vegas
      I actually looked at that product, but having the remote battery disconnect on your key chain was a big plus for me... like a cheap theft deterrent
      One thing I will say is when its all hooked up on your battery... its ugly lol
      1964 Impalla SS pro-touring -sold
      1969 Camaro RS pro-touring -sold
      1969 Camaro SS pro-touring -sold
      1972 Camaro Z28 pro-touring -stolen
      1987 Grand National pro-touring
      May 2007
      Jax, Fl or lost in the Ga woods
      If your using an optima, or that type battery you have to use a Different unit !!
