Results 1 to 12 of 12
Thread: Another fuel line question
02-17-2009 #1
I am getting ready to mock up fuel lines on my car and I need some guidance. I have a modified fuel tank with 1/4" NPT fittings on top in a slightly recessed area near the sending unit. The pump is in the tank.
I need to come off the top of the tank and forward, then turn to the right after the front of the tank, kind of like the way GM did it with the stock lines. After that I will be running into a filter and forward with steel or plastic lines.
I think that I need to make enough tight turns at the tank that I'd prefer to use steel there as well. I'm a little worried about braided lines chafing something or getting chafed and I don't want to worry about fuel smell seeping through the lines.
Whadd'ya think?
02-17-2009 #2I would suppose the steel line would be superior to the braided line....for the part you are working on (out of the tank and to the filter). The braided line is much larger in diameter....prolly twice as large, so yes, the chaffing/rubbing and possible blowout would be a concern for me.
If at all possible, use some cut fuel lines over the steel line to prevent any rubbing or rattling.
Hope this is what you were looking for,
~Joe
02-17-2009 #3
