      florida
      Wheel offset help
      I currently have 18x7 front wheels with 4.25 offset. They rub just slightly and I am looking at 18x8 with a 5.25 backspacing. I am am moron I guess but what will the outside lip of the wheel do with the 18x8s?? will it move in .5??
      florida
      or will it be the same?? 1inch wider wheel, 1inch more backspacing??
      florida
      anyone?
      Aug 2003
      Usually with 8s we only do a 4.75 BS, but your already way over that 3.25 front space with only a 2.75 front space on your current set up. Where do you rub? outside or inside? You should not rub on the outside even a little with a 2.75 front space. On your alignment, how much negative camber do you have?
      florida
      I rub on the outside, I guess I should have specified this is with air ride, and I believe I am -1degree camber. I just need my wheel to sit in from the outside lip another .25 would be perfect
      Aug 2003
      If you have to pull the wheel in that much, you will not clear a 8" wheels. You would need to add the one inch for extra width + the addtional 1/4" you need, you will have a backspace of 5.5" and there will not be enough room on the inside for that much BS.
