    Thread: Uneven 67
      Albuquerque NM
      Uneven 67
      So I want to start upgrading the suspension on my 67 Camaro, but before I start, I want to correct a problem on the rear suspension. The car was 6 cylinder with mono leaf rears when I got it 19 years ago. It looked as though the drivers side had a sagging rear spring. so about 6 years ago I put on a fresh set of multi-leafs. Did not change anything. I work @ a paint and body shop, so I got the car up on the frame rack and tried to twist it around a bit. Helped a little. The car still sits lower on the driver side rear. About 3/4" - 1". Anyone else experience this issue, solutions? I would like to get it resolved before upgrading the rear suspension. Also when I had 255s on the rear drivers side would rub, even with rolled 1/4 panels. Never rubbed on passenger side. Any help?
      Orlando Chavez
      67 Camaro,
      33 Ford 3 window i
      Mountain Springs, Texas
      How are the subframe bushings? If the subframe is sitting twisted due to compressed bushings it can cause the back to be out of level.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      savannah,ga
      This is an issue that I am studying as well. my 67 Firebird does the same thing. My buddies 73 T/A does this also. maybe its a subframe issue?
      Albuquerque NM
      I had not even thought of that, i will check it out. thanks
      Orlando Chavez
      67 Camaro,
      33 Ford 3 window i
