    Results 1 to 17 of 17
      Arlington Heights, IL
      Trans Am GTA wheels???
      Im thinking of picking up some super cheap GTA wheels for a temporary set up. I saw a camaro with some on here. anyone know what im talking about? I can find it.
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      and also. Those third gen ta's came with 2 different backspacing for the front and rear. anyone know which i would need on a 68 camaro?
      thanks!
      Feb 2006
      Idaho Falls, Id
      I have a GTA and a 67 Firebird. I once had the rears on the rear of the 67 and they fit fine. I forget which is front and which is rear but one has a zero offset and the other is +16 and I'm pretty sure they are 8" wide. Let me know if you want some measurements and I'll get them tomorrow. Infact I have an extra of each in my shop so I'll just measure them and post it if no one beats me to it.
      Traven
      Apr 2004
      OKC, OK
      I posted a pic of a customers white 69 with GTA aftermarket wheels with different correct offsets. If you are running originals the rears have to go on the front.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Where do i get aftermarket GTA wheels?
      Apr 2004
      OKC, OK
      He got his from Classic Industries. Don't know if they still carry them or not.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Try to get 4 fronts. The offset is more to the outside and they have a deeper lip, ie they look better. The wheels say front and rear on the back. These wheels will not fit some cars due to the hub hole size.
      A good set of 4 driver condition front wheels will bring $400 to a Buick Grand National guy. The rears do not have much value since nobody wants them except the GTA Trans Am guys.
      It's pretty easy to Ebay single "front" GTA wheels that are nice for $100+ Dollars so If you get a set of 4 that includes 2 front and 2 rear just consider that when you negotiate a purchase price.
      Mike
      www.musclecardeals.com
      Apr 2004
      OKC, OK
      Quote Originally Posted by CamaroJesse View Post
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      So the fronts will fit for sure?
      Dec 2008
      Clearwater, FL
      Those are fronts. I used to have them on my 73 GMC Sprint that was lowered on the ground.
      Im assuming these brakes will clear just fine with these gta wheels?
      Dec 2008
      Clearwater, FL
      you might have an issue with C5 brakes. Those are only 16" wheels and you might want to check the clearance. Depending on the size of the rotor they should work.
      Apr 2004
      OKC, OK
      Your gonna need 17's to clear C5 brakes.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      oops sorry i ment to put a link in there. i ment these.
      http://www.ssbrakes.com/commerce/det....cfm?nPID=1195
      Apr 2004
      OKC, OK
      Those will fit but need to check caliper clearance. They should have a template
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2007
      Pittsburgh, PA
      I have C4 brakes on my GTA and the stock mesh wheels fit, but it's close. Take a look at thirdgen.org as some guys have used the C5 setup and will surely know of any fitment issues. Last time I looked, Classic still sold new GTA rims. I think they were 199 each. Sad part is, finding a nice set of originals is getting much harder, and much more pricey.
      78 TA, 400 4spd
      72 Chevelle, 454 4spd
      72 Demon
      72 Dart
      70 Dart
      70 Charger
      69 Roadrunner
      55 Chevy
      70 Duster
      68 GTO
      ...ain't projects fun?
      Nov 2004
      Dallas Texas
      Jesse
      I posted this on your other thread so here it is again:
      "back in the late 80's I put 4 16x8 rear Iroc wheels on a 70 R/S the fronts IIRC needed some minor spacing and I painted them body color too - early P/T car with T/A sway bars and gear box. The GTA rear wheels could also be done and painted centers. the fronts would stick out too far so all wheels were rear position.and I was running P255/50zr16 gatorbacks for spacers i used the rear spacers off the IROC too"
      I would do rear wheels the front offset will more likely rub the fender lip
      hopes this helps you out!
      these wont fit with the C5 12.7" setup max is a 12" or 1LE brakes now if you havent done the C5 brakes yet- you'll be OK
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
