    Results 21 to 40 of 61
      Yo gearbanger, that rotisserie looks awesome! The road to full restoration is a long one, but just like college it'll be finished before you know it. Well, on second thought I could be wrong! Atleast the resotoration will be fun! Could I be wrong again?
      Feb 2006
      Yeah mudbone, thanks for the help on the rotisserie. If it takes as long to restore this thing as it did for me and you to get out of college, I think I'll just put it back together now! Ha HA!!!!!
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Feb 2006
      Well it's been a while and I thought I would make some updates. So far I have the frame boxed and narrowed 1.5" each side fore rear tire clearance. Through all the welding the frame has remained square and level. I was worried that it would twist up on me. I have the welds mostly dressed and I and taking it next week to get a coat of powercoat primer. That way I can see where I am as far as the way my welds look and if I need to dress them some more. And I will have the frame protected for several more months of work and body and paint work. Once the body work is all done, I will separate them again so that the frame can get its black powder and the body can be coated underneath and the exterior painted.
      I also got my new moser axles today and I cut my 12 bolt housing for the 9" ford ends. The housing and axles are 1.5" narrower than the previous rear setup. In the next couple of weeks I'll be getting the housing powder coated and the rear rebuilt and back under the car. This will put my tires 1/2" from the frame on the inside. I have 295/45/18 now. Pleanty of room for up to a 325 in the future.
      I have a new set of rear tubs that will be getting widened 2" for extra tire clearance as well. I'll have to remove the body mounts that are right behind the rear tires and relocate them a few inches rearward.
      The body has been getting some attemtion too. I have all the holes filled in the firewall. I am going to use a heater delete plate to block the heater hole. I wanted a more factory look there instead of making it all flat. I welded the cowl seam solid and will fill the rest and block it flat. It will be satin black under the hood so it will kind of look stock only better.
      I have most of the floors fixed. I made a plan in the beginning to remove as little factory metal as possible and so far it is working well. I had to rebuild the lower cowl on both sided and the ends of the front two floor braces. I have become a pretty good welder at this point and I can tell I am alot faster at fabbing a panel and getting it welded in than I was at the beginning. I am welding the floors from the inside and that just leaves a little bead on the bottom to be ground flat. It will look like nothing has ever been done from the bottom.
      This is going to take a while but I am really enjoying it. It is really going to be cool to know that I did all of this when it is said and done.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Nebraska
      Great lookin car. Can't wait to see it as you make progress on it and what you end up doing with it.
      Put Up Or Shut Up!!!
      Southern California
      Great work on the frame, I did the similar work to my Chevelle. As for the rotisserie, is there a way/spot you could drill and tap a 3/8" hole in the center section and thread a bolt in it. I have that on mine, tighten down the bolt locking it in any position. I have bolt on both ends and it works great. Also, maybe consider a spreader bar between both front and rear supports so it will roll easier and not spread on you as you rotate it....just a thought.
      Love the car, great start and it will be killer when it's done!
      Nice work it looks good.
      Feb 2006
      Idaho Falls, Id
      Nice!
      Traven
      Feb 2006
      Alot has been going on in my life recently, we had a little boy named Spencer Steven Godsey. He was born November 20th. It has been really crazy since. Family and friend had flocked to us like never before to check the little guy out. I am really glad I got this resto going before he was born. I want to have it done before he is a year old so I can spend maximum time with him during those super fun and amazing months of learning and development.
      The car has come a long way but still has a ways to go. I have it back on the frame temporarily and just about have my new tubs put in. They have been widened 2" and should alow for plenty of tire in the future if I wanted to step it up. The frame has a coat of powder coat primer and the suspension is starting to take shape in front. I am switching from the B-body spindle swap and 12" brakes to the stock spindles with the SPC Stage II+ setup. So far it looks really sweet! I will be using the Wilwwod 12.19" setup all the way around, so I can use 15" wheels again if I ever wanted to. After all this car is going to the grave with me!
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Dallas TX
      Looking great Alex! Congrats on the new critter. We just found out we will have a second one comming in July. I already can't keep my 4yo daughter out of the shop. I'll be in real trouble when they start double teaming me.
      Feb 2006
      Thanks gearhead! I loved your build thread. I suck at taking pictures and trying to capture the flow of work. It is pretty crazy every time I look at my project I think, Man, I am just not getting much work done, but then when I think about it, it really has come a heck of a long way. You just work and work and work and one day, bam, it's done. So many parts of the body work is spent making problems go away, and so it doesn't look like anything has been done. But when I look back at the before pics I am like man, I have really done some work!
      I have a guy lined up to paint it in May. He does nothing but GTOs. This will be his 20th GTO! He mainly does stock, of course, but he has done so pretty cool modified ones. This will be the most modified one he has done though. I think he is pretty stoked about it.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Feb 2006
      Here is a shot of my temprary cross member. I am kind of proud of my cross member mounts that I had to make after boxing the frame. I am going to make a totally new crossmember and has maximum room to get the exhaust up. Believe it or not, this is the factory location of the tranny mount, basically flush with the bottom of the frame. I can raise it about a half inch but that is about it. I am thinking of making a piece of 1/2" thick steel that makes a shape like ____ ____ to go over the exhaust and under the tranny
      / \___/ \
      mount. Then finish it out with 1-1/2 box like the temp is made of. That way everything is flush with the bottom of the frame. I am planning to mod my headers or make new one to get the whole exhaust up flush with the bottom edge of the frame. I hate to see the exhaust hanging down.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Feb 2010
      Your project is coming along really nicely, can't wait to see it finished!
      BJ
      66 GTO LY6/4l80e
      Build Thread on LS1tech
      Feb 2006
      Well the car is now at paint prison. I got the underbody finished and most all the metal work exept the quarters and the rear window well that had some rust. The frame is powder coated with the freshed engine, tranny and new narrowed rear end installed. New Varishocks all the way around powdercoated springs. I still have to plumb everything and get some disc brakes front and rear. I have gone back to stock drum spindles with the SPC stage II+ kit. 99% sure I am going with the KORE3 corvette brakes front and rear but I am still a little worried about not being able to fit 15" wheels on the car. I might get the urge to go back to the muscle car look one day and that will suck if I have to change disc brakes to do so later. The Wilwoods are about the only other choice at this point. Should be about another couple of months on the paint. Then I can get it back and start wiring and plumbing, interior, chrome, and glass. I absolutely can't wait. It is turning out to be a much more intensive restoration than I initially intended. It is so hard to just "paint the car". You get in there, and it's like, how can I just half way do it, when it just takes a little more time and money to do it perfect?
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Jan 2010
      Delaware
      Scarebird has a disc brake conversion for the pontiacs that fits behind stock 15" rally's. Not sure if he's on this board but you can look him up on performanceyears.com tech forums. He's the man when it comes to the smaller discs with Pontiacs. Personally I want all out handling and will never go back to a 15" wheel
      Looking good though!
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Rustburg, Virginia
      Wow, your car was nice as it was....can't imagine it getting even better.
      A friend of mine in HS bought a 67 Lemans against the will of his father and he managed to hide the car at my house for almost a year before finally breaking down and telling his Dad that he had it. The car was the same color as yours in the first pics/post. His had the 326/PG, but it didn't take him long to build a 428 for it and tossed in a TH400....car ran strong.
      Can't wait to see more of your car.
      Feb 2006
      I am really looking forward to it having a/c and being so much more solid due to the boxed frame and repaired body munting points and poly mounts. It should really be a different car! I am still struggling with brake choice. I was set on the KORE 3 setup for a while but I have gone back to the idea of being able to install 15" wheels for drag strip use or just in the event the pro-touring look gets old. (Heaven Forbid!!)
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Rockford Illinois
      I'm sitting here wondereing if you drove it to the wedding?
      Nice car and hopefully you will be able to contain yourself and keep it all together and find driving is really more fun than working on them. Your 1st auto x or trackday will help cure your problem I guaranteee it !!!!!
      Feb 2006
      Sure did! Did a big ole burnout too leaving the reception. That is, after I put my coil wire back on. My buddies really thought that would trip me up. As soon as I hit the key and it didn;t fire, I hopped out and popped the hood and stuck the coil wire back on.
      The really cool thing is that my dad bought a new 67 GTO when he and my mom got married. He picked it up the day of the wedding and they left their wedding in a new 67 GTO too. I think my dad really thought that was cool that day. I wish he could be here to see the car when it is better that new, but that just the way it is.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Feb 2006
      Well it been quite a while since an update but I have big progress to report. The car is painted and back on the frame. It has a long way to go but man does it look nice. I will have it back in a couple of weeks with all body panels assembled and ready to begin wiring, plumbing, brakes, and interior this fall. I can't believe it is finally red again. I never thought it would run again. I will have to rename my project now! It is now "Project: Just Might Run Again"!
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      San Antonio, TX
      Congrats on getting parole from paint jail! The car looks fantastic.
      Dave
