    Results 1 to 20 of 23
      Abingdon Va.
      Frustrated as $#@&!!!!!
      Let me vent a little and blow off some steam and get some opinions and what I should do. First off the guy that blasted and replaced sheet metal said to just replace what was needed to be replaced ie use skins instead of full quarters. Then he made basically patch panels instead of using full skin, Driver side look pretty good until the final sanding for paint and the seams looked like a map on side of car. Pass. side looked like someone put a 3 ft long 2 X 4 on and flaten the patch panel out. So body man replaced that side before final sanding. The first guy just said we have changed the way we install the pieces now but that doesn't help you now ole well sorry. The body man told me he would charge 5k for labor to paint the car plus materials. He has had the car since June 08. in which he did some work on car and replaced the one qrtr skin. After we discovered the map on the driver side qrtr I opted to just repalce the qrtrs with full qtrs. The body man was kinda down in his back, so I have friend that is very particular about what he does and he said he would install the qrtrs for me. Went back over to visit the body man to let him know where we stood on the car and he informed me that he would not be able to finish the car due to his back and neck issues. I had already paid him 3700 on the car threw 3 total payments. Looking at the car I just don't see that much work on it, but in his defence he did have time in qrtrs the first time around in which are being cut out. I only techinically owe him around 2300 to finish up the car. I don't feel i will be able to get some one else to finish the car for that considering they will be trusting his work to put there rep on. So I am trying to figure out how I should handle this. If you have any suggestion on what I should do I would appreciate it. This is all suppossed to be fun not a slow death.
