Results 1 to 20 of 395
Thread: '64 Plymouth Fury
02-09-2009 #1
'64 Plymouth Fury
It's taken a couple years but I found a '64 Fury 2-door, which I've always dreamed of dropping and giving a NASCAR kind of vibe. Problem is, what I bought and what I was told I was buying were two entirely different things! I don't want to get into the whole sordid tale of my stupidity, rather I'd prefer to focus on the task at hand an the progress I'm making, so here goes.
Before I start though I want to commend all the contributors on this site: I've been lurking around for a while looking for ideas and it's AMAZING how much you guys all support each other. I hope to become active and help others when possible.
These are shots of the car I received prior to purchase. Looks can be VERY deceiving! Beneath the metallic Gray paint was more rot and plastic filler than metal, so I stripped the car of every nut and bold and had it acid stripped.
Neither of the quarter panels are actual Mopar sheet metal! Both appeared to be scrap sheet metal riveted in place then slathered over with filler, which in places was over 1" thick!
Below is just a little of what we found: I've got more shots I'll post later, including the floor, which will be replaced in its entirety after we install full frame rails (2" x 4" rectangular tubing). The opposite quarter was just as bad!
One of the biggest problems is the fact nobody makes a complete quarter panel for the Fury so you end up having to use a couple different stampings, making alignment and attachment that much more difficult.
After the acid stripping the real extent of the damage was apparent, so here's what we're doing to remedy the problems:
New trunk extensions (both sides):
Cut away the rot and move the remaining inner wheelhouse inwards 2.5".
Then install the new quarter panels (in pieces):
After that we filled in the gap between the new quarter panels and the inner wheel house. I did the right side first and did it in two pieces but decided to fill the left side in a single sheet. Damn that's a lot of work!
It's funny because I was worried about fitting a large enough tire under this thing, but when I put one of my friends 335/35/17 (on a Compomotive HB) under the car I ended up with 2" - 2.5" worth of clearance!
Once we knew the 335's would fit I went ahead and ordered rims. My friend had good luck with the guys at Intro so I checked 'em out and found their "Pentia", which I think has an excellent retro theme while incorporating a modern edge. The spokes and center will be powder-coated Titanium while the lip will be polished. I think this contrast will look bitchin' on a black car.
Sizes are:
Front: 17" x 9.5"
Rear: 17" x 12"
Now that we've got most of the rear rot issues taken care of it's time to begin moving on, and here are the plans:
- 51" truck arms with coilovers
- 9" floater with 3.90's (approximate)
- Complete C5 Vette front suspension with coilovers: we may or may not use the Chevy K-member I have, it just depends on the engine fitment. If there's any oil pan or pulley issues we'll make our own.
- Remove all front sub-frame and fenderwell material and replace with the full length frame mentioned above.
- Move firewall back 1" - 2"
- Install Art Morrison 12 point cage
- Install fiberglass hood, trunk, fenders, bumpers, and doors
- Install 500+ inch RB with D1 Pro Charger
