    Results 1 to 12 of 12
      Arlington Heights, IL
      Time to figure out backspacing.
      Im getting ready to buy wheels and have to figure out my backspacing. I have no idea how to do this. What do all you guys do? I dont want to buy that expensive tool for it. I can barely afford the wheels.
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      New York City
      It's always best to ask for help from people who have fitted similar combinations. After that you still have to measure to verify that your car can use one of those suggested (you know back to that all these cars are a little different and you have to measure both sides...ect). This link should help you to get started measuring without expensive tools. http://www.chevyhiperformance.com/te...all/index.html
      Feb 2007
      USA, TN
      You might want to call ATS. It looks like you have their spindles and brakes.
      Yeah i do have the ats spindles. maybe ill talk to Tyler.
      So. Cal.
      I made a lil tool just to measure my car for wheels. I wanted to get the fit oh just right. My clearances were tight. I made mine outta steel but you could do the same with wood or even stiff cardboard. Definitely measure though. And those wheelrite tools are nice, just kinda pricey for a one time use. JR
      Oh, and with mine being 3/16" steel plate I could grab it and turn the rear end through its travel to check for clearance, and the rear end didnt wanna turn so easily, disc brakes dragging a lil.
      My home grown measuring rig..
      Oct 2007
      Georgetown/Austin, TX
      Wow! ^ That is awesome. You even simulated the bulge of the tire...lol You should mass produce those.
      East Washington state
      remember to check out the first sticky thread here in wheels and tires thread list. Find cars with close components to yours and see what they have for bs. Search using things like ....bs..B.S., back space. wheels fitment,etc. etc. Keep searching, I found most all info I needed already posted. Take advantage of the wealth of information that is offered by Frank at Prodigy Customs, but be sure to also repay him by buying from him and other venders here on the site.
      LaMont Mulligan aka munster, leroy, mull, just don't call me late for dinner..
      My car is Therapy. 69 - Firebird into Camaro wana be. Sheep in Wolves Clothing. DSE tubs, Air Rides Airbar Rear susp., CPP Tubular CA's w/Shockwaves, Unisteer Rack&Pinion, RS Hideaways, Polished calipers, drop spindles, 4wheel disc, Be Cool rad, 18" Coddingtons Junkyard Dogs w/12"wide mod on rears, BFG KDW's 335/30/18 & 245/40/18 fronts. 383 Stroker, Edelbrock Vic Jr Heads and Manifold, lunati cam solid Roller, Pro-Magnum Roller Rockers, Demon, MSD Dist, 6AL, Thorely Tri Y ceramic coated headers. Converted to 68 dash. Moser narrowed 12 bolt and fitted for Airbar.
      So. Cal.
      Quote Originally Posted by CliffsBlueCamaro View Post
      Haha, thanks, I just copied the wheelrite design, give them credit. And I think I can do that, its just for my own use LOL I do it all the time. I see a tool that GM or Ford wants to charge an arm and a leg for, I just copy it. Guess we are allowed to right.. Copy it and improve it, thats easy. JR
      Ya thats a neat little tool you got there. Maybe ill try to rig something up like that.
      Feb 2007
      USA, TN
      Quote Originally Posted by JRouche View Post
      That looks a lot sturdier than a Wheelrite.
      So Cal
      We should all own a tool like the very nice one made by JRouche, definitely makes it easy to be sure what will fit.
      Check out the diagram at the bottom of this webpage. It outlines a pretty simplified approach, but gives you a basic idea of how to go about it.
      http://earlywheel.com/products.html
      If you have no tools other than a straightedge (yardstick) and a tape measure, you're not too bad off. I've been able to shoehorn some pretty big wheel/tire combos into quite a few of my cars using nothing but a yardstick and a tape measure.
      One of the best tools to use to measure off of is your current wheel & tire or even just a bare rim. At least this way you have an actual wheel to go from, it's not too hard to use a 15X7" steel wheel to see where an 18X9" wheel might fit if you use it as a point of reference.
      Measure a lot at first, and then measure some more.
      Every car is slightly different, so measuring your own car instead of taking someone else's word on what fits is always best.
      Of course the word of some of the experts who have fit numerous wheels and tires on the same car as yours is pretty solid, but it never hurts to check. Especially if your car has a non-stock rear end in it, both the F-body and A-body cars from the different GM divisions used different widths for the 10 and 12-bolt rears. It's not always going to be a slam-dunk using whatever wheel width and backspacing some other guy said worked on his car.
      Case in point: This '66 VW Type II pickup with 16X8.5" '84 Corvette wheels & 205/55-16s. Who was I going to ask about fitting this freaky wheel/tire combo to this ride?
      You can barely get your pinky finger between the rear fender and the tire. Inside there's less room than that between the tire and the springplate (connects the trailing arm to the torsion bar). The rear suspension drops down just far enough that you can work that rear tire & wheel out of that tight, low-cut fenderwell opening.
      I got out the measuring tape and went to work. I originally bought these for another car (back in '89), but after doing a little measuring I found out they would fit my VW without any spacers or adapters (I got lucky to say the least).
      After doing a front disc brake conversion ('71 Bus discs/modified stock spindles with caliper brackets welded on) and converting the rear suspension from swing axle to Type I Bug IRS (aftermarket kit to adapt) I was able to have the hubs redrilled to the Chevy 5 on 4.75" pattern.
      Figuring out what will fit your Camaro oughta be easy compared to what I went through with this crazy VW pickup.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Sep 2007
      Livermore, Ca
      here is a link to a site that helped me out alot when finding out what would fit good. http://www.rims-n-tires.com/rt_specs.jsp
