      Feb 2008
      Snohomish, WA
      degreasing an engine on the stand
      Anybody have any easy way to degrease an engine while it's on the stand. I pulled a big block out of a truck to put in my Camaro and I want to degrease, clean and paint it before dropping it in. There are so many options out there but has anyone found a good, easy, possibly non-toxic way to do it. I have a pressure washer but not sure that hosing it down with Gunk and blasting it with the pressure washer is the best option.
      Oh ya, and any recommendations for engine paint would be appreciated too.
      Thanks everyone,
      R
      Robert F.
      Everett, WA
      Castrol Super Clean.
      Scrape off as much crud as you can with a wire brush and a putty knife. Spray on the Super Clean, keep it soaked with the stuff and let it do its job over night.
      Come back the next day, lightly mist some water on the block and scrub away the rest of the grime. A toothbrush works great for the nooks and crannies.
      After all this - use wax and grease remover from an auto paint supply shop to get rid of ANY remaining gook.
      Paint? Good ol' DupliColor rattle can of high temp engine paint is what I use. Lots of colors to choose from.
      The few, the proud, the crazy... the LT1 owners.
      Feb 2008
      Sesser, Il
      x2 on the Dupli-Color. I did a light coat first and when that got a bit tacky, put on 1-2 more light-to medium coats. Just enough for good coverage.
      I also agree on the above cleaning method.
      Doug Gulley
      Feb 2008
      Sugar Land, TX
      I had been a Super clean fan forever until I started researching making my own biodiesel. One of the "drawbacks" I read is that it does such a super job of cleaning the fuel system, that it may leave you on the side of the road with a clogged fuel filter. That got me to thinking of using it as a degreaser. I have and have never looked back. Years ago, my wife's Toyota Highlander had a severe sludge problem. I de-sludged it and kept some of the molasses-think sludge I found in the rocker covers. I can hold the container upside down and it won't move its so thick. Biodiesel dissolves it in seconds and its easy on the hands! Give it a try and let me know how you like it.
      StephenL
      1967 Olds Cutlass Supreme
      Feb 2008
      Snohomish, WA
      Hey everyone, just thought i'd follow up on this. I decided to try the biodiesel and it worked pretty good. Not sure how good compared to Castrol but it worked good enough to break up 20 years of grim on my 454 with a little work here and there with my nylon brush. I went with B99, which is 99% veg oil at a cost of $4.50 for a gallon. I bought one gallon and a plastic spray bottle I've still got plenty left over, only used about 1/2 a squirt bottle so far but I'm not quit done either. Anyway, for anyone looking for a less toxic way to degrease give it a try.....Thanks for everyones assistance and idea's!
      Robert F.
