      Andersonville,TN
      Fuel Pick up questions
      Hello, I am building a 1979 Malibu and have a few questions about the fuel system. I want to run a factory style fuel tank but must have constant fuel supply or else (turbo BBC). I have read about the fuel cells and all that and do not like the look of a big square box hanging down in the back. I also want a trunk that is useable. Is there some type of fuel pick-up that I could build or sump that I could make to keep fuel to the engine during braking,acceleration, and cornering G's? I will not spend the money to have a custom fuel tank made, 1000 bucks is a bit much for me.
      Ryan
      Ca
      I was wondering the same thing. Hopefully someone will chime in.
      This is what I've found so far.
      https://www.pro-touring.com/forum/showthread.php?t=281
      http://www.iimuchfabrication.com/Tanks/
      http://www.geocities.com/hrayhouston...ank.html?20093
      Feb 2008
      Sesser, Il
      I was going to mention the dropped tank sumps but I guess that is the big square box you don't like to see hanging down.
      I tried... nevermind.......
      I need sleep
      Doug Gulley
      Andersonville,TN
      Well not really, the big box I do not like is something like the fuel safe cells that hang down. A sumped tank would be fine but I do not see how that would contain enough fuel to keep the pump supplied in cornering. Maybe it would, that would be an easy fix.
      Jun 2005
      Lynnwood Wa.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Dec 2007
      Carlsbad, Ca
      heres another i started on the chevelle site.
      http://www.chevelles.com/forums/show...=261083&page=1
      Tim
      Build Thread Link
      May 2009
      Arizona
      This is a set up for a Mustang but the same thing can be done to just about any tank.
      http://www.glennsperformance.com/pro...roducts_id=145
      If this motor is going to require a large fuel system (As I would assume it would) then you really should think hard about a sump.
      Those big pickups are fine but I would not use them over 400 ish HP that's me though. That said I've used the stock system up to that power level N/A. It was undersized but I had no problem with the pump having to suck out of the tank while running a small suction filter. In a forced induction set up I would not want to take any chances on going lean so err on the side of caution and sump your tank is my advise.
