      Feb 2008
      Mooresville, NC
      Racepak G2X help needed!!!!
      I am having trouble figuring out how to get the "open track" feature to work properly. This is what would be used for an autocross track. I can make the track map, set up the start and finish lines, and break the track up into segments. The problem I am having is when I do this I don't get any entry or exit speeds for the segments. I do get the split-times for each segment though.
      Also when I try to upload another run using the same track map the "X" to represent the car will not move around the track. I dont know if I am following the correct procedure.
      I hope this is enough information for someone to understand and any help would be greatly appreciated.
      Central CA USA
      I need to figure this out too, I haven't used mine on an autox course yet.
      Can you send me your files?
      I need two files, the run file, and config file.
      David
      Big Stone Gap, Virginia
      Call!!
      Call Racepak and talk to Tim Anderson!
      Mark
      Ability is not being able to do something once or twice.Ability is being able to perform upon demand!!
      Feb 2008
      Mooresville, NC
      David
      David,
      You have mail! I also sent you the track map file.
      Michael
