      Dec 2008
      Engine Questions!
      1) 11:1 Compression ratio is that able to run on 91 octaine?
      2) When you build an engine what was the breaking it in steps. Like when to change oil, re torque etc...?
      Thanks!
      Apr 2008
      Anaheim, Ca
      1)need more info cam specs, quench, head material, etc. in short it can be if built right
      2)Need more info again flat tappet engines break in have more steps then roller cam engines
      Kenneth N.
      1969 Mercury Cougar XR-7 Boss 429 clone under construction
      Dec 2008
      hydraulic roller cam settup with a 4.80 lift roller rocker arms, i havnt decided what heads i want, for sure not aluminum.
      Loganville, GA
      The 95 Trans Am I had (LT1, 10.5:1 cr, aluminum heads, reverse cooling, A/T) would spark knock on Quick Trip 93 octane in the summer. It did better with Amoco 93. Even confirmed this at the track. It ran 14.80's on QT and 14.40's on Amoco, just one week apart. Weather conditions were the same.
      Now my El Camino is 11:1 with aluminum heads and it so far hasn't had any problems with knocking. It is running a slightly rich fuel mixture, which may be helping when under load. No problems cruising around. I believe that you may be pushing it on 91 octane without some sort of octane booster. Just my $0.02 worth.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
