    Thread: bending hoops
      Jan 2009
      bending hoops
      Anybody out there that is good at bending hoops. Do you guys use bend tech or some other method for not wasting material? thanks
      Jan 2009
      So-Cal
      I bend quite a bit of tubing and cant remember the last time I scrapped a tube. All I use is a tapemeasure and two peices of flat stock bolted together as a "bend gauge". It helps to start with a center line. For bending you want to figure the gain from the start point of the bend to the outside of the bend radius. If you are rich a bend protractor can make things a little easier. They are available here...
      http://www.mittlerbros.com/tube_bending_accessories.htm
      Feb 2009
      Manitowoc Wisconsin
      Bend Tech Pro makes it pretty easy. If you are just starting out, it's the best way to go. I've used it for years.
      Quote Originally Posted by BAILEIGH INC View Post
      ^^^ I have used BnedTech EZ for simple bends and it works great!
      Quote Originally Posted by Damn True View Post
      Occupant comfort and the eardrums of the neighbors kids are secondary concerns.
